LabWindows/CVI
Excel ChartWizard / ChartSetSourceData
I’d like CVI generate a chart in Excel which has X&Y axis titles.  I’ve run into two problems, only one of which I need solved.
Problem #1
If I use the ActiveX Excel_ChartWizard function, it does not correctly generate an XY scatter plot.  (The problem has been posted before for CVI; no solution yet).  Using this function I can get my axis titles.
Problem #2
I can create the desired XY scatter plot using ChartApplyCustomType and ChartSetSourceData.  The problem is now that I cannot create XY axis titles.  Among several other things, I’ve used the Excel_SetProperty function in an attempt to set Excel_AxisHasTitle and Excel_AxisAxisTitle.  As of yet, no luck.
So I can either have axis titles and a bad chart, or a good chart with no axis titles.  Thanks for the help.
Randall
(3,766 Views)
Hello Randall,
Do you already have a test project that demonstrates both problems?  I haven't used these functions as of yet, so I would be better able to help if I had this starting point.
Thanks!
Message Edited by Wendy L on 12-06-2005 04:04 PM
Wendy L
LabWindows/CVI Developer Newsletter
(3,734 Views)
