LabWindows/CVI
Excel Report - OLEObject functions
Hi ,
I'm using CVI 9.0 .
I'm trying to add my Excel report a Rectangle Shape and Line shape , i'v tryied to add it using OLEObject with no luck...
is there an example ? or some guide ?
Kobi Kalif
Software Engineer
Message 1 of 9
(6,858 Views)
Hi KobiKal,
Here is some fairly exhaustive ActiveX examples for Excel with CVI.
Hope this helps!
Dustin D
Message 2 of 9
(6,828 Views)
Hi Dustin , 10X for the replay
Where are the Examples ?
Kobi Kalif
Software Engineer
Message 3 of 9
(6,821 Views)
in the menu bar: Help / Find examples...
Message 4 of 9
(6,817 Views)
Hi KobiKal,
Here is the link.  Sorry about the confusion.
Dustin D
Message 5 of 9
(6,801 Views)
KobiKal,
These examples will be good to check out as well:
Dustin D
Message 6 of 9
(6,795 Views)
Hi Dustin ,
I know this examples and before i'v posted mt question I'v my Report with them .
Everything is complete except of one thing i am trying to add A simple rectangle to the Work Sheet But still with no luck .
What i'm trying to do is shown in the Picture that i'v added to this post .
Maybe you can help me is there and example you know with shapes ? or maybe you have something like that ? 17189i30D70876117D0320
Kobi Kalif
Software Engineer
Message 7 of 9
(6,726 Views)
Accepted by topic author Kobi_K
Hi KobiKal,
You may be able to write a macro or VBA script that will draw the shape that you can call from CVI.  It seems like there is a limitation on creating shapes with the ActiveX interface to Excel.  Your best option would be to code a VBA script that you can call via ActiveX.
Hope this helps!
Dustin D
Message 8 of 9
(6,690 Views)
10X I'm using macro code and its working great !
Kobi Kalif
Software Engineer
Message 9 of 9
(6,621 Views)
