LabWindows/CVI
Exception 10H when running standalone exe
Hi all
I'm using Labwindow 5.01 and I have the following problem:
When I have created a executable and run it I'm getting a Exception Error
10H from windows. The error doesn't appear when running inside the Labwindows
environment and my guess is that it is related to an event function that
is run at a different time and may be missing an referece to a object.
Is there a way to debug into where the program is causing the exception ?
I would like to be able to decode the stack dump and so on
Thanks in advance
Klaus
Message 1 of 1
(2,959 Views)
