LabWindows/CVI
Executable icon doesn't update when .ico file is changed
I'm having a similar problem to this thread, but with my executable file.
I have a project in LabWindows 2015 SP1 using Windows 7 Pro.  I created an icon file and set my project to use it by selecting Build -> Target Settings -> Application icon file with Configuration set to "All Configurations".  Later I created a different icon file and changed the target settings to use the new file.
When I build my application, I'm seeing something strange.  The icon that shows up in my Windows folder for the application is the old one, and if I create a shortcut to the application on my desktop, I get the old icon.  But when I run the program, the icon in the upper left corner of my main panel is the new one, and so is the one that appears in the taskbar.
I tried the solution suggested in the original thread (deleting the cvibuild.xxx folder), but it didn't help.
I did find another solution -- renaming either the executable file or the folder containing it to any other name causes the icon to change to the correct one.  So this isn't a big problem, but I thought I should report it anyway since the behavior doesn't seem right.
If I subsequently rename the file or folder back to the original name, the icon reverts to the old one.
(7,951 Views)
Hi richferrara,
Thanks for reporting this issue. This is a known issue with LabWindows which is mentioned in the LabWindows™/CVI™ 2015 Known Issues. Please try the instructions in the KnowledgeBase article below to see if it works for your executable for another workaround.
Josh
(7,899 Views)
I tried changing my icon file and following the instructions in your link, but it didn't work.  My application still showed the old icon when I navigated to it in Windows.
(7,880 Views)
Did you try the method in the linked Windows Club link?
There is also another way to do it, should the above method not work for you:
Kill Explorer.exe process. In Windows 7, click Start button > Hold down Ctrl+Shift & Right Click on an empty area in the Start Menu > Click “Exit Explorer”.
Open the command prompt window, type each of the following and after every command, hit the Enter button:
cd /d %userprofile%\AppData\Local
attrib –h IconCache.db
del IconCache.db
start explorer
(7,856 Views)
Once I click "exit explorer", how do I bring up a command prompt window?  The start menu is no longer accessible.
(7,851 Views)
