LabWindows/CVI
Export Variable or Struct from CVI DLL to TestStand
I am using LabWindows/CVI 2012 and TestStand 2012.  Is there a way to export a variable or structure using DLLEXPORT (or some other method) and access it from TestStand the way you access exported functions?  Thank you.
(2,292 Views)
I'd take a look at the article below
Embedding Type Libraries in a LabWindows/CVI DLL for use in TestStand
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJ23SAE
(2,260 Views)
If I understand it correctly, Type Libraries are more for functions in the DLL and their parameters.  It seems that TestStand doesn't know what to do with a variable that has been exported from the DLL.
(2,235 Views)
