LabWindows/CVI
External exe launched in a rectangular region drawn
Please find an attachment. Kindly have a look on .uir file in the example. If i want to launch any external exe say e.g cmd.exe in the rectangular region drawn, what will be way of doing this as i am unable to launch .exe in the rectangular region specified.
Thanks & Regards.
Moshi.
(3,016 Views)
Hi Moshi,
you seem to join the unfortunate tendency to post the very same question multiple times: If people can't assist you it won't help repeating and doubling your question - it would be better to continue your original thread, see here
(3,013 Views)
Hi
Yes I have posted the question 2nd time beacuase I have not got reply of my query in my original thread. I was just posting it as the main topic so that most of the people can see and assist.
Regards.
(3,010 Views)
Moshi,
You can use pipes to do this, though when I tried this I couldn't get a reliable solution. I abandoned pipes and simply coerced the output into a file that I then read in. This is a very crude solution and I suspect isn't very future proof but it works in W7! Code below might help:
  sprintf (Cmd, "\"%s\" > \"%s\"", BatchFilePath, OutputFile);
  Ret = system(Cmd);
  if ( Ret < 0)
    //file is not there
    sprintf( Msg, "Can't run %s, error: %i", Cmd, Ret);
   return Msg;
(3,001 Views)
