LabWindows/CVI
External trigger and E-series boards
I am trying to synchronize the begining of an aquisition process from 4
different analog input channels. I used the Signal_select function (
required for e-series boards) to set my trigger parameters (Analog
trigger) and the DAQ_Config function before the DAQ_Start function. How
ever it does not work. I don't know what else to do any ideas???
I can use also a digital trigger (since the analog trigger is big
enough) How ever I couldn't find a function that uses difital trigger
for analog daq. Any ideas anyone?
Message 1 of 1
(3,140 Views)
