LabWindows/CVI
Extract either string1 or string2 from another string
I have a string of data named "dump" with 500 or more bytes of data that will contain within it either (along with other data)  the word "circle" or  the word "square". (but not both)
I need to pull which ever one of these two words that is in the string "dump" and to create a string called "type" that contains only  that word.
Is there an easy way to do this with a line of code or two?
thanks
(3,191 Views)
if (FindPattern (dump, 0, -1, "circle", 0, 0) >= 0)
   strcpy (typem "circle");
else if (FindPattern (dump, 0, -1, "square", 0, 0) >= 0)
   strcpy (type, "square");
(3,190 Views)
