LabWindows/CVI
Extrapolation of an isotherm
Please, I am intraineeship and I work on a project and I have been blocked for several days on a problem.
I trace an isotherm that arrives up to 0.23 and I want to extrapolate to 1.
If there are tools that do extrapolation on CVI thank you for helping me or give me ideas how to do.
Thank you all.
Message 1 of 8
(3,780 Views)
I teach my students that extrapolation typically is BAD and that only interpolation is permitted - the only exception is if one has a reliable (verified) model for the data. Then one can use the model to predict the behavior.
So this means that
  1. you need a model function (say a square root dependence)
  2. you need to verify your model in the data range of your interest (i.e., around 1) - otherwise you can just throw a dice because then the extrapolation mostly depends on your model
Concerning CVI this means that you can search for a function that does least squares fitting - and depending on your model you may have to use the NonLinearFit routine
Hope this helps Smiley Happy
Message 2 of 8
(3,762 Views)
What is the right answer !!
Message 3 of 8
(3,742 Views)
OK thanks for your answer.
Please give me an example of using NonLinearFit, I can not find and I do not know how it is used, I have not understood the documentation
Message 4 of 8
(3,739 Views)
Sorry, I wasn't clear. I wanted to say my message was a wrong posting!
Message 5 of 8
(3,738 Views)
Okay
thanks anyway
Message 6 of 8
(3,736 Views)
In CVI, use the menu entry Help / Find Examples, enter nonlinear as keyword.
This requires that you have the Advanced Analysis Library, i.e the Full Development System of CVI (menu Help / About to find out)
Message 7 of 8
(3,722 Views)
Okay,
I will look
thank you very much
Message 8 of 8
(3,718 Views)
