LabWindows/CVI
FATAL RUN-TIME ERROR: "phasedif.c", line 210, col 5,
FATAL RUN-TIME ERROR:   "phasedif.c", line 210, col 5, thread id 0x0000080C:   The program has caused a 'General Protection' fault at 001B:00000000. During evaluating function from Advaced Analysis Library. Twice reinstalled the whole LabWindows (LW). The error occured, as you can see, even in LW examples. What shall I do. Need fast reply.
Thanks Bejn
(3,932 Views)
What version of LabWindows/CVI and Windows are you  using?  Do you only get this error if you are running something that calls analysis.h, or does it crash other times also?
Kristen
(3,909 Views)
LabWindows 8.0. And the problem seens to be only in analys.h functions. I reinstall LW three times without success and then I returned back in operation system to the point it worked and it started to work. Probably uninstall doest work well and some informations get stacked in register. Realy dont know what caused the problem, because I didnt install anothing on my PC at that time. But thanks for replay
(3,887 Views)
Hi Bejn,
So, just to clarify, your Advanced Analysis Library is working now, right?  Were you able to get it working by using the system restore option?
Marty H.
(3,867 Views)
Yes, just uninstall all CVI prograns and again install them again was not sufficient. Even if I made registry cleaning in the second try. Just return of the system registry to the point where everything was OK helped me.
(3,852 Views)
