LabWindows/CVI
FATAL RUN TIME ERROR with CVI 7.1, A non-debuggable thread caused a 'General Protection' fault at address 68647163
I'm running a multithreaded program in LabWindows CVI 7.1.
There are four threads in my program with:
- reads and writes on RS232
- reads and writes with DAQmx 8.6.0f5 to a module USB6008
I sometimes have  the following error
in debug mode and release mode.:
FATAL RUN-TIME ERROR
Unknown source position, thread id 0x00000E88
A non-debugger thread Caused a 'General Protection ' fault at address 68647163.
 Is there a way under CVI 7.1 to  know what's the problem  ?
Note:
I'm running my programm under this PC:
Windows XP /  Version 2002 / SP3
Processor = 2.7 Ghz
RAM = 3Go
Thank you for your help,
Christophe
(3,853 Views)
I don't know if we can debud or spy a FATAL RUN-TIME ERROR, I need verify.
Can you try on a more recent LabWindows/CVI version ?
Have you an simple example that reproduce the error ?
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,828 Views)
thank you for your prompt response.
I don't have a simple exemple that produces the error.
When I simulate USB6008 and RS232 commands, the program don't produce any error.
I will first do a test by installing the application on another PC this week.
Il the error occurs, I will create the program with CVI 8.0 and test it.
thanks,
Christophe
(3,811 Views)
