Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
FFT
FFT
baki
Member
01-14-2004
03:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
In the discription of the advanced analysis lib function FFT(CVI 6.0) I do
not find any hint that the size of the sequence is a power of two.
Is it posible to use an other sequence size?
Babak
Kudos
Message
1
of 2
(3,197 Views)
Reply
Re: FFT
bilalD
NI Employee (retired)
01-15-2004
02:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello
You should be able to use a sequence of any size with the FFT function. However, using FFT on a sequence the size of a power of 2 will run alot faster.
Bilal Durrani
NI
Bilal Durrani
NI
0
Kudos
Message
2
of 2
(3,197 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
