LabWindows/CVI
FTDI FTD2xx.lib with CVI2020
Hi all,
Has anybody managed to build a CVI project using the latest (2.12.36.4) FTDI files ftd2xx.h and ftd2xx.lib downloaded from the FDTICHIP.COM web site?
I have tried including these files in my CVI project but am presented with linking errors when building.
FTDI have an example CVI project that I have download and installed in the same environment and that builds under CVI2020 ok. This example is very old and includes much older versions of the two files in question but it does build.
If I replace the old ftd2xx.h and ftd2xx.lib files that came with the example project with the latest versions of those file, back come the linking errors.
I contacted FTDI but they say "it should work with CVI" but they are not able to provide support for CVI specific issues 😞
Any help would be most appreciated.
(1,742 Views)
After much head-scratching I spotted what I had done wrong …
I was wanting to use the dynamic library but had included the static version of the ftd2xx.lib file in my CVI project.
Corrected that an it now builds and links correctly.
(1,706 Views)
