LabWindows/CVI
Failure to load instrument when adding fp file to project
In CVI version 7.1, why does does the associated instrument not load when adding an fp file to the project - if right click on the workspace/project pane (with a single project added) and select -> Instrument Files -> Add Files - >Browse for file ?
Note that if adding an fp file via the menu selection Edit>>Add Files To Project>>Instrument(*.fp)>>Browse for file it does load the instrument
Message 1 of 1
(2,768 Views)
