LabWindows/CVI
Fast loadin data to table
I looking a way for fast loading data to table.
For example:
I have data structure of Students.
struct STUDENTS
     int    ID;
     char Name[15];
     char Lname[20];
     int    Picture_BitmapID;
I create a table wich collumns suitable data types. (Numeric[int], string,string,picture).
I have 10,000 records. If  i using "for" loop on each row and use SetTableCellAttribute(,,ATTR_CELL_VAL,) its  very slow for each cell.
Is there a way to load data more faster?
Best Regards
Boris
Best Regards
Boris
(4,868 Views)
To optimize performance and minimize the number of times that a table draws, use the SetTableCellRangeVals and FillTableCellRange functions. These functions set the values of multiple table cells, so they are more efficient than calling SetTableCellVal multiple times.
To minimize the number of times that a table draws, you can hide the table prior to calling SetTableCellRangeVals or SetTableCellVal.
(4,864 Views)
Thank you very much.
I saw this function but I do not know to use on different variables.
Where can I find any example?
Thank you
Boris
Best Regards
Boris
(4,854 Views)
Some related posts can be found e.g. here and here
(4,849 Views)
