LabWindows/CVI
Fatal Run-Time Error dialog box size
Is there a way to set the size of the Fatal Run-Time Error dialog box?  While debugging you will sometimes get a Fatal Run-time Error, see attachment.
But looking at the dialog box you can see that some of the information is not visible.
The filename and what was expected are missing.  The dialob box is not resizable on the fly, so I would like to set it larger that default.
(3,581 Views)
Hello Paul,
I don't believe there's a way to set the size of this dialog box, but I have seen similar problems (not with CVI) when working with screens with  very high resolution, have you tried by chance to see if changing the resolution of your system has any effect on this?
(3,540 Views)
