LabWindows/CVI
Fatal Runtime Error Debugging
My PC has both CVI-2013 as well as previous version CVI2012. However while working with 2013 project whenever run-time error occurs, And if I press 'Break' to debug the code it opens CVI2012 and pops up a message " Unable to attach process for debugging. Either permission denied or Invalid process id".
How to set the option to use CVI2013 for debugging purpose.
(2,818 Views)
May I know which version of run-time that is installed in your PC?
Based on the KB below, you do not need to specify the version of run-time.
Installing Multiple Versions of LabWindows™/CVI on the Same PC - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kKoXSAU&l=en-US
(2,743 Views)
