LabWindows/CVI
Fatal error with VAL_CLOSED_HAND_CURSOR
I am getting a fatal error calling: SetMouseCursor (VAL_CLOSED_HAND_CURSOR);
Is this a known problem in CVI 7.1.1, it seems to work with other cursor types incl. VAL_OPEN_HAND_CURSOR.
Paul.
(2,849 Views)
Hello, Paul
Yes, there was a problem with that specific cursor in CVI 7.1. It was fixed in CVI 8.0. If you're not going to be upgrading to 8.0 any time soon, you can download the 8.0 version of the CVI runtime here,which should fix your problem.
Luis
NI
(2,829 Views)
