LabWindows/CVI
Fatal internal error MemoryManager.cpp, line 406
I have a CVI program that calls into a dll created from a VI.
When the VI is compiled with debugging off, the program runs, but doesn't return the reults I expect. So I turned on debugging and tried to step into the dll.
That results in the line 406 error.
I've searched my drive for MemoryManager.cpp, but I guess it isn't provided (or I didn't install it)
What should be my next step in tracking this down?
(4,377 Views)
Found it!
I was assuming (wrongly) that the error out structure would be allocated in the dll. No, it has to be created before passing it into the dll.
(4,374 Views)
More info on how I found the problem.
My dll had lots of parameters passed in - gains, errors in, errors out, etc. To debug, I tried to pass in NULL for most of the parameters and the function ran without an error (good NULL checking on NI's part). So I just replaced with real parameters one at a time until I found the problem.
(4,347 Views)
