LabWindows/CVI
FileExists and UNC path
I tried to reproduce this behaviour with CVI2010 SP1, but it always returns 0 both if I use the host name or the host IP address.
Is it possible that this issue has been fixed in the latest releases yet?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 11 of 12
(1,006 Views)
We are not aware of any explicit fix to the FileExists function, though it is possible it may have been indirectly fixed. Will you be able to use CVI 2010 SP1, or do you need to run your application with an older run-time engine?
Message 12 of 12
(987 Views)
