LabWindows/CVI
FileExists() to take into account letters in Caps?
I am using this function FileExists(&file_name,0) and would like to know if there is a way to make it take into account capital letters as well? For exaple file names file1 and File1 should not return FileExists as positive.
Thank you!!
Sinnas
Message 1 of 10
(5,657 Views)
The source code of FileExists is in toolbox.c, so you could inspect and adapt it (in a copy...)
Message 2 of 10
(5,653 Views)
Oh ok thanks Wolfgang.. it doesnt seem possible though as it only looks for size of the file not characters.
Thanks anyway!
Message 3 of 10
(5,649 Views)
Actually I did not understand your original problem, but are you aware of the ANSI function tolower() ?
Message 4 of 10
(5,645 Views)
Yes i am aware but what im am looking for is for my application to distinguish between C:\Appli\file1 and C:\Appli\File1;
The application will look to see if file1 exists and should not return positive value if File1 exists.
*using ghost drives
Message 5 of 10
(5,643 Views)
I would assume that it depends on the file system, FAT32 isn't case sensitive so there is nothing fopen() can do... (as far as I know)
Message 6 of 10
(5,636 Views)
Oh i dint know that. Ok yes that helps. thank you!
Message 7 of 10
(5,631 Views)
Based on this knowledge base article from Microsoft, NTFS volumes should permit having files that differs only in case, but a serious limitation is that win32 applications cannot correctly access them: MS mentions Notepad as an example, I suppose this is valid for CVI programs too if developed in 32-bit mode.
A very basic attempt with this code resulted in a single file with lowercase name as the first one created but with the second text in it:
#include <formatio.h>
static int		fH;
fH = OpenFile ("c:\\temp\\test1.txt", VAL_WRITE_ONLY, VAL_TRUNCATE, VAL_ASCII);
WriteFile (fH, "One line of text\n", 18);
CloseFile (fH);
fH = OpenFile ("c:\\temp\\Test1.TXT", VAL_WRITE_ONLY, VAL_TRUNCATE, VAL_ASCII);
WriteFile (fH, "Another line of text\n", 22);
CloseFile (fH);
Message 8 of 10
(5,630 Views)
This is because NTFS is sort of special, in principle it is case sensitive but one cannot create files differeing only in case. Wikipedia
Message 9 of 10
(5,625 Views)
Cannot create, cannot copy, cannot move, cannot rename... I wonder if having two files differing in case is practically possible!
Message 10 of 10
(5,617 Views)
