LabWindows/CVI
FileSelectPopup and Windows 7 library folders
Hello everyone,
I have a problem using the FileSelectPopup on Windows 7. When I open a FileSelectPopup and click on "Libraries" (I use a german OS where this feature is called "Bibliotheken", so I hope you get to the point) to select a file in Documents for example, then the return value is 2 (a new file was selected, not an existing one) and the file path starts with strange characters.
The call to FileSelectPopup that I use is the following:
ret = FileSelectPopup ("", "*.txt", "*.txt", "Select file to import labels", VAL_SELECT_BUTTON, 0, 0, 1, 0, sFileName);
Is this a known problem or limitation of the FileSelectPopup?
I am using LabWindows/CVI 2010 SP1.
I have attached a screenshot of the IDE at a break point just after the call to FileSelectPopup.
Thank you for your comments.
Best regards
Hagen
(3,962 Views)
Yes, this is a known issue that is being addressed in the next version of CVI.
Sorry about the inconvenience.
Luis
NI
(3,953 Views)
I am seeing the same issue in LabWindows 2012.  FileSelectPopupEx works okay, but FileSelectPopup doesn't.
(3,824 Views)
Yes, that is the expected behavior, unfortunately. FileSelectPopup will always have this problem. The solution to this problem was to introduce the FileSelectPopupEx function.
:ios
(3,809 Views)
