LabWindows/CVI
FileSelectPopup does not display network folders.
A client is complaining that File Browser does not display network subfolders. I have verified the same problem on my machine.
I am using FileSelectPopup function for CVI 8.0.0 running on WinXP:
#define XML_FILE_EXTN "*.xml"
  lStatus = FileSelectPopup (pszDirList[0], XML_FILE_EXTN, XML_FILE_EXTN,
           XML_FILE_DLG_TITLE, VAL_SELECT_BUTTON, 0,
           0, 1, 0, pszSingFilePath);
Have you reported this problem before?
(3,150 Views)
I couldn’t reproduce the behavior you describe.
I was able to browse to network locations both mounted and through the “windows network”.  What version of Windows are you using?  The file popup browser does nothing more than call a Windows function that displays the file browser.  Many programs probably use the same function, are you having problems with this in other programs (such as opening a file in MS Notepad)?  Perhaps I’m missing the problem too, as maybe you are referring to something different that I haven’t tried.
Message Edited by Travis M. on 05-05-2006 12:27 PM
Travis M
LabVIEW R&D
(3,129 Views)
