LabWindows/CVI
FileSelectPopup not using the current working directory
Have run into a probem with the CVI library function "FileSelectPopup": it doesn't use the current working directory as the default; uses the root directory instead. This seemed to happen when I upgraded to CVI 7.0 or 7.1. I use SetDir() to set the current working directory but it doesn't have any effect.
(3,768 Views)
Hello, Alex
You are right. This was a bug that was introduced in CVI 7.1. It has been fixed, and the fix will be released with the next version of CVI.
I apologize for the inconvenience.
Luis
NI
(3,759 Views)
