LabWindows/CVI
Find Resource no longer works
I had code that was working in CVI 2019.  Currently running in 2020.  Here is a snippet of my code:
result = viFindRsrc ( rmHandle, "PXI?*INSTR { VI_ATTR_MODEL_CODE == 29435 }",
&findHandle, &numSynchBoards, visaResource );
In the past this would dynamically find the 6672 in my chassis.  Now it errors out because it can't find the resource.  MAX finds it and self-test passes.  Repaired NI-VISA and NI-Synch.
Tried using FindRsrc.c example program to find all resources (?*INSTR) and it found my other VISA instruments but not my NI-Synch card.
Did VISA change?
Message 1 of 1
(1,166 Views)
