LabWindows/CVI
Firmware uplading with VISA
Hello all,
I'd like to try and control an EZUSB-FX microcontroler using VISA USB, if
possible both in Windows and Linux (haven't tested VISA there yet).
But the first thing I need to do is to upload a firmware to the card. How
can I do this using VISA ? The firmware is in the form of an Intel format
..hex file. For instance on Linux it is uploaded with the fxload command; and
on Windows it can be autoloaded with the Intel LoadEZ driver...
Since I need to upload it every time the card is reset, I'd like to do this
from the CVI program... I guess there must be some VISA command for this but
I'm not yet familiar enough with them.
Or maybe I can modify the VISA inf file to autoload the .hex file ?
Thanks.
Guillaume Dargaud
http://www.gdargaud.net/
"So i open a can of pepsi max and i see on the side: 'Best Before: See
base of can' so i turn the can around and i feel a cold chill running down
my legs..." - King_Kane.
(3,182 Views)
Hello Guillaume,
Have you tried using viWriteFromFile?  You should be able to use that function to load and write a file to your VISA Resource.  The Help File for that function is below.  Please let me know if you have any other questions!
Meghan
Message Edited by Meghan R on 04-20-2007 03:02 PM
(3,161 Views)
I get "Visa Error: Unable to start operation because setup is invalid
(usually due to attributes being set to an inconsistent state)."
I assume the options are not properly setup and I'm still very hazy about
what this card needs in term of configuration.
I'll have to look it up.
Guillaume Dargaud
(3,136 Views)
