LabWindows/CVI
Folder rename.
Does anyone know how to rename folders (Win98/CVI5.5)?
John Cameron.
(3,330 Views)
You can use the function "rename" from ANSI C library.
As an example, create a folder named "Test" on your C drive ("C:\Test") and run the following code in Interactive Execution Window:
#include
#include
char OldDirPath[MAX_PATHNAME_LEN];
char NewDirPath[MAX_PATHNAME_LEN];
int status;
strcpy (OldDirPath, "C:\\Test");
strcpy (NewDirPath, "C:\\RenamedDir");
status = rename (OldDirPath,NewDirPath);
After executing this code, the previously created folder (named "Test") will be renamed in "RenamedDir".
Beware that on MS Windows, this function fails if the "OldDirPath" and "NewDirPath" do not refer to the same disk drives.
Silvius
Silvius Iancu
(3,330 Views)
RE Folder rename.,
silvius said;
>Hi,
>Window:
>#include
>#include
>int status;
>Regards,
>Silvius
Thanks, I'll try that on Monday.
John Cameron.
(3,330 Views)
