04-10-2006 07:29 AM
04-11-2006 05:55 PM
Hi Erik,
I am not sure what's happening what is happening in your code, but have you taken a look at the wordrpt.prj shipping example? You can find it by going to Help>>Find Examples and searching for ActiveX. This example creates a table in Word which sounds just lik you describe your target. The column headings are bold and underlined but the rest of the text is normal. Perhaps you can use this example as starting point.
If this doesn't help, perhaps you could post a very small section of code which is producing an unexpected result
Good luck!
Megan B.
Applications Engineering
