LabWindows/CVI
Force Measurement using NI 9219
I want to use NI 9219 for force measurment using a loadcell that take a maximum Excitation of 18 [VDC or VAC] with rated output of 2mV/V and bridge resistance of 700 ohm. attached is the spec sheet for referece. through my search in NI website I found a tutorial for load measurement for NI 9237 (Tutorial is attached). Can NI 9219 also measure load using the same method. if so, is NI 9219 compatible with attached loadcell spec. I looks that maximum excitation is 2.5 V. will NI 9219 be able to read 2 mV/V?
Load Measurment Tutorial
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1jjCAA&l=en-US
Loadcell spec Sheet
http://www.futek.com/files/pdf/Product%20Drawings/llb300.pdf
(4,152 Views)
Hi Alsaati,
This is the wrong forum for your question.  This forum is for questions regarding programming in the LabWindows/CVI environment.
If you have questions about the NI 9219 capabilities, please post them to the Multifunction DAQ forum: https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
I think you will have better luck if you post your question there!
G-IV
(4,133 Views)
