LabWindows/CVI
Formatting functions
Hi
I want to convert an integer array into a string with each byte interleaved by a 'space'. How do I do this with Fmt or Scan function,
The length of the integer array will be  a variable one and so in the formatting functions( Fmt and Scan) it should be of arguement type.I read in the help file that , the length of the array can be mentioned as arguement by using astrisk(*) in the Fmt or Scan function. Please tell me with some example
(3,379 Views)
If the length varies, you will have to use variables in your format strings.
This will give you a string of integers separated by spaces with a trailing space after the last value ("1 2 3 "):
Fmt( TargetString, "%s<%*d[j1] ", arrayLength, dataArray );
This will give you a string of integers separated by spaces with no trailing space after the last value ("1 2 3"):
Fmt( TargetString, "%s<%*d[j1] %d", arrayLength - 1, dataArray, dataArray[arrayLength] );
I am the founder of CnCSoftwareSolutions. When not cleaning up baby drool, I write about test data or work on Vision, a tool for understanding your test data. Visit me at www.cncsoftwaresolutions.com
(3,373 Views)
