LabWindows/CVI
Function CycleRMSAverage
I would like to use this function calculate the RMS value of a 5 kHz, 15 V positive peak, -15 V negative peak  square wave signal.  My array data file name is dOutput, and the size is 300.I am not sure how to enter all the parameters for this function.  Can you provide all the parameters?  Thanks.
(3,041 Views)
LMTO,
Below is the link to the detailed description of the CycleRMSAverage function for CVI. This should be able to help you use the function as you wish, as it describes the parameters and what order you will need to place them into the function.
CycleRMSAverage
http://zone.ni.com/reference/en-XX/help/370051T-01/cvi/libref/cvicyclermsaverage/
Renée M
(3,030 Views)
