LabWindows/CVI
Function Tree Generation with Function Pointer
From this page,
http://zone.ni.com/reference/en-XX/help/370051T-01/cvi/usermanual/srcoptgenfunctree/
The Generate Function Tree command does not support typedef identifiers for function pointer types.
I have a function with a parameter that is a pointer to a function, and I can't get the function tree generation to work correctly. I'm thinking my problem is related to that article above, but is there a way around that problem?
Kevin Key
(3,426 Views)
Still wondering if anyone has any information on how I can get a function added to the function tree that accepts a pointer to a function as one of its parameters.
(3,405 Views)
Hey Kevin,
In order for CVI to recognize custom data types such as function pointers, you must first typedef your identifier.
For more information there is a knowledgebase article dedicated to this issue.
Please check out Generating a Function Tree When Using a Function Pointer Parameter.
Jake G.
(3,399 Views)
