LabWindows/CVI
Function calls
I have a CVI that takes up to 30 minutes to complete one of the tasks. I
want to make it possible for the user to quit during the download if they
want to but I am having trouble doing that from within the download loop.
I have tried GetUserEvent, ProcessSystemEvents, and several other functions
inside my loop and can't seem to get them to do what I am asking. Is there
a way to exit out of the loop if someone clicks Quit on the user interface
while a seperate function is already running?
Thanks.
(3,677 Views)
Hi Marlise,
Use a global variable as a terminate flag.
Set the flag in the callback for your quit button.
Test the flag in your loop, and terminate the loop
if the flag is set.
Don't forget to call ProcessSystemEvents() inside
your loop.
Reed.
Reed Blake
Beta Technology
Industrial and Scientific Computing
Marlise wrote in message <38ce91cf@newsgroups.ni.com>...
functions
>Thanks.
(3,677 Views)
Hi Marlise,
I suggest you to put the part of code that consume time proccess in a
seperate thread and all the rest user interface mechanism handling in the
main process thread, check out the following example:
#include
#include "Panel.h"
static int panel;
static BOOL CancelRequested=FALSE;
void Thread_SomeTask()
while(CancelRequested==FALSE)
// Place your task here
Sleep(500);
InsertListItem(panel,PANEL_LISTBOX, -1,"I am still busy",0);
// Other things to do
ExitThread(1);
int __stdcall WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,LPSTR
lpszCmdLine, int nCmdShow)
BOOL result;
DWORD ThrdID,ExitCode;
HANDLE ThrdHandle;
// Create a separate thread for some task that consume long time
ThrdHandle=CreateThread(NULL,0,(LPTHREAD_START_ROUTINE)Thread_SomeTask,NULL,
0,&ThrdID);
// Load, Display and Run the UserInterface loop
panel=LoadPanel(0,"Panel.uir",PANEL);
DisplayPanel(panel);
RunUserInterface();
DiscardPanel(panel);
// Make sure that the task thread was exited normaly
do
result=GetExitCodeThread(ThrdHandle,&ExitCode);
while(result == TRUE && ExitCode == STILL_ACTIVE);
CloseHandle(ThrdHandle);
return 0;
int CVICALLBACK MainPanel_Exit (int panel, int control, int event,void
*callbackData, int eventData1, int eventData2)
switch(event)
case EVENT_COMMIT:
CancelRequested=TRUE; // This will make the thread to stop
its loop and exit
QuitUserInterface(0);
break;
return 0;
news:38ce91cf@newsgroups.ni.com...
functions
there
> Thanks.
(3,677 Views)
