LabWindows/CVI
Function panel question
I have a DLL which has following function:
int __stdcall omniBER_Init(char* pResourceName, int* pHandle, char*
pErrMsg);
Now I am asked to make a fp file, which I did. In fp file editor, I
declared my 3rd param to be "output" and type "char".
But when I use this panel (run interactively), CVI only declares a
variable char and passes it by ref. to the above fn. What I want to do
is declare my buffer, like char buf[80] and be able to pass buf to this
function panel (when run interactively). Is there a way to declare
variables (in the interactive mode) where I can select variable name and
type and then use them in the fp?
vishi
(2,919 Views)
Don't worry, seems I can not use FP file with just a DLL and header
file. It associates to a C file.
vishi
> pErrMsg);
> type and then u
se them in the fp?
> vishi
(2,919 Views)
