LabWindows/CVI
Function search lockup - 2009
The first time in a session when I try to use the Functions search from the block diagram it often (several times a week) locks up. An hour glass appears and I let it sit for 5 minutes but labView is then unresponsive and must be killed. If editing multiple VI's only one shows up in the recovery list. Is this a new feature of the 2009 version or is this an old problem?
thanks,
jvh
(3,201 Views)
Hello jvh,
you have posted your question to the wrong board: since your problem refers to LabVIEW you should post it here.
(3,198 Views)
Apologies! I must better watch where I am clicking.
jvh
(3,196 Views)
