LabWindows/CVI
GP Fault with CVI5.5 and SQL 2.05
Group,
I have been reading the threads about CVI5.5, SQL2.0, and VC6 SP4 having
problems,
I am new to ODBC programing, but my code connects to the DB with no problems
and I am able to update my UIR with the data, no problems, but here is my
problem when I try to write the updated data from the UIR back to the DB:
// Connect DB Works OK!
// ActivateDB Works OK!
// Bind Col SQL Works OK!
// Fetch Works OK!
// GetCtrlVal Works OK!
// Local Variable Updated Works OK!
// DBPutRecord General Protection Fault!!!!!!!!!!!!!!!
Arg!!!!!!!!!!
OP System: NT4 Client
Softwar
e: All listed above
What am I missing?
Gregg
(3,099 Views)
Gregg:
Could you please tell me more about your system: what database and version are you connecting to? Also, what version of ODBC do you have on your system? What other information accompanies the GPF; there is usually a module and offset listed.
It may be easier to continue this discussion via National Instruments Email support. You can request email support from http://www.ni.com/ask
Best Regards,
Chris Wood
(3,099 Views)
removed fetch command, works fine now
Gregg
(3,099 Views)
