LabWindows/CVI
GPIB Instrument Settings: VISA Properties (in NI Max)
When I open up the "VISA test panel" in NI MAX (5.1.0f0) for my GPIB instrument (GPIB2::22::INSTR), under "I/O Settings" (, the termination character is set to line feed \n. I select "apply changes". When I closed the "VISA Test Panel" and re-open it, the "Enable Termination Character" is selected. To keep the "Enable Termination Character" select does the VISA Test Panel need to remain active? Is there a more permanent solution for this setting?
(2,989 Views)
Hi KE2,
That is expected behavior; the test panel is meant to be a temporary quick test.
A more permanent solution would be to write LabVIEW code to do this, or use the LabVIEW GPIB example.
Here's our documentation on how implement this with a property node:
How to Add Termination Characters to VISA Serial Writes in LabVIEW
http://digital.ni.com/public.nsf/allkb/862567530005F09C862565BE005AB500
Alex
Hardware Engineer
(2,953 Views)
Good Morning Alex:
I will test your recommendation to see if that solves the issues we are having.
(2,931 Views)
