LabWindows/CVI
GPS Time
Hello everybody,
I'm working with a device which provide me with GPS time,
as far as I know, it should be time since the beginning of the week...
My question is:
Is there a built in functions to display GPS time in DD HH:MM:SS format or any other format??
Thanks in advance,
Aj
Amit Joseph,
Software Engineer
(5,006 Views)
What data type is the time in?
If it's a timestamp you can simply use the timestamp to string function.
You should know that GPS time is different than your computer's time - it's currently 16 seconds different.  Check this out for more information: http://en.wikipedia.org/wiki/Global_Positioning_System#Timekeeping
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(5,000 Views)
Chris,
thanks for the quick response...
in matter of fact, the data I recieve is string which I'm gonna translate to int (or what ever fit), unless there is a type of variable which I can use to ease the work 🙂
is there a way to convert this INT to timestamp?
thanks,
aj
Amit Joseph,
Software Engineer
(4,997 Views)
If you actually want a timestamp, you can use a combination of the Seconds to Date/Time and Date/Time to Seconds VIs - you can get the current timestamp, use the Seconds to Date/Time function to pull out the components (day, hour, minute, etc.), replace those with the values you get from your reading, and then bundle it back into a timestamp with the Date/Time to Seconds VI.
Chris
(4,987 Views)
Accepted by topic author Amit_J
Well, coming to CVI world ( Smiley Wink ) you can take a look at CVITime functions from the Utility Library: if your instrument returns a string representation of time, you can use extract individual components from the string and pass them to CVIAbsoluteTimeFromLocalCalendar () function that returns time in National Instruments Binary Time Format.
Alternatively you can use Windows SYSTEMTIME format and associated functions.
You can finally use MakeDateTime () to obtain a double representation of date and time.
(4,983 Views)
Darn it!  I keep forgetting to check which forum I'm on . . .
Oh well, same idea I guess. . . Smiley Frustrated
Chris
(4,980 Views)
