LabWindows/CVI
General Protection Fault caused by CVI ToolTip
Hi folks,
When I quit my application in debug mode, I always get a General Protection Fault when the application's panel is discarded. After some research, I found out that the problem is caused by using the SetCtrlToolTip functions from the Programmer's Toolbox. When I put toolbox.c in my project, the debugger gives the GPF in the UnchainPanelCallback  function, which is called by SharedTipPanel_Dispose. The debugger stops at line 10528 of the toolbox.c file, which contains this code:
 while (!found && currLink && currLink->signature == CALLBACK_LINK_SIGNATURE)
Strange thing is that I use these ToolTips in all my applications, and this is the first time I experience this problem...
Anyone has a clue?
(4,583 Views)
OK, I solved the problem. All I had to do was initializing the panel's callback data to NULL. Actually I persumed that this is already set to NULL when no callbackdata has been specified...
(4,545 Views)
Could you please tell me how you "initialize the panel's callback data to NULL"?
(4,537 Views)
Here you go:
SetPanelAttribute (pnlHandle, ATTR_CALLBACK_DATA, NULL);
(4,535 Views)
