LabWindows/CVI
General Protection Fault encoutered while reading ARINC429 data
 My program is set to read data using a Ballard ARINC board and write the data to a log file.
It runs well if no data is received, but when the first time valid data arrives, the program encounters "Genral Protection Fault....."  and pauses at the entrance of the function below:
 void MakeLogMsg(char * msg, LogFilePtr lfp)
 The "msg" string  and "lfp" pointer were valid at the time.
Ps: The program had ran well before I added the loging funtion.
(3,815 Views)
Just a guess: is "msg" string nul-terminated? You may have problems if treating non nul-terminated strings. If the string is ok, can you add some details more on your code?
(3,797 Views)
Accepted by topic author ziczac
Problem solved!
The string is nul-terminated. Just my program will enter a dead loop if valid data arrives.
 Anyway, thanks for your consideration, Roberto.
(3,786 Views)
