LabWindows/CVI
'General Protection' fault at 001B:
HI,
I am getting GPF, when i call a  function from dll which is created with release build configuration. If i buid the dll using debug build configuration, when i call the same function, it executes fine.
When the dll is release build congiguration, when i call the function, it enter into the function and executes some steps/functions, after that it throws GPF, I found out this using print statements...
can anybody have any idea, how to solve this?
thanks
CAK
(2,777 Views)
Could you post the full error message and version CVI that you are using. Also, are you able to identify exactly which function is throwing the error?
(2,757 Views)
