LabWindows/CVI
General protection fault with CWIviDmm
I'm trying to use the ActiveX control CWIviDmm. It works fine until the end of the application, because when I call QuitUserInterface, a fatal run-time error occurs with a general protection fault. Does this behaviour be known?
(3,065 Views)
I got the same problem and no solution yet.
You might follow an older link:
http://groups.google.de/group/natinst.public.labwindows-cvi.general/browse_thread/thread/606ba4b57e7...
There the problem is described in more detail. You might get an idea, what to try.
T.B.
(3,041 Views)
I've written my own IVI driver for my Agilent 34401A and if I compile it in release mode I don't have this problem anymore (but the problem is still happened when I compile the driver in debug mode! Very strange!).
Hope this help.
(3,027 Views)
