LabWindows/CVI
Generate import libraries for third party dLL
I want to include the nonlinear fitting module in the labwindows software. And I have got the dll file and it's header.
I have some difficulties to generate the import library. Is there anyone can help me.
I have attached the files. They can also be found in the following link.
https://nlopt.readthedocs.io/en/latest/NLopt_on_Windows/
(3,612 Views)
What did you try? What didn't work?
Rolf Kalbermatter  My Blog
(3,470 Views)
The fact is I don't know how to generate the library in labwindows
(3,464 Views)
It's described in the help in LabWindows/CVI. http://zone.ni.com/reference/en-XX/help/370051AG-01/cvi/programmerref/generatingimportlib/
(3,458 Views)
Thanks for your reply.
However, I haven't generate the desired .lib file. I have attached the files. Could you please have a look?
Best,
(3,416 Views)
Give the same name to your .h and .dll. Open the .h, [Tools][Generate Import Library], add the result to your project, add the include to your .c, use the functions from the dll and that's the gist of it.
(2,773 Views)
