LabWindows/CVI
Generating FM signal generation in LabWindows/CVI
Hello Community,
i was looking for an example project that generates FM signal using LabWindows/CVI.
I appreciate your help on this topic.
Regards.
Muhammed Karlitepe
(1,412 Views)
Hi M_Karlitepe,
I was not able to find any examples, shipping or otherwise, for a FM receiver in CVI. What I was able to find was an example for LabVIEW, and a CVI shipping example for FM demodulation using NI RFSA. You should be able to figure out how to make a FM receiver in CVI using the combination of these resources. However, you may need some addtional toolkits for signal processing.
NI-RFSA: FM Radio Receiver in LabVIEW: https://decibel.ni.com/content/docs/DOC-30233
Assuming you have the NI Modulation Toolkit, with CVI support installed, the CVI shipping example for FM demodulation using NI RFSA can be found in the following directory:  C:\Users\Public\Documents\National Instruments\CVI\samples\amodt\for niRFSA\FMDemodulation.
Regards)
_______
Best way to thank is to give Kudos / Mark as a solution.
(1,220 Views)
