LabWindows/CVI
Generating Sin Wave with NI-6733
Hellow ,
i'm tying to create a sin waveform and i don't know if the way to create this wave is similar to creating analog normal analong volt output
this is what i did :
int AnalogOutputSin (double *freq,double *amp,char chan[256] ,double *offset)
 int         error=0;
 TaskHandle  taskHandle=0;
 char        errBuff[2048]={'\0'};
 float64  freqCast;
 float64  ampCast,offsetCast;
freqCast = *freq;
ampCast = *amp;
offsetCast = *offset;
  // DAQmx Configure Code
  DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
  DAQmxErrChk (DAQmxCreateAOFuncGenChan (taskHandle, chan, "", DAQmx_Val_Sine, freqCast, ampCast, offsetCast));
  // DAQmx Start Code
  DAQmxErrChk (DAQmxStartTask(taskHandle));
  // DAQmx Write Code
  DAQmxClearTask(taskHandle);
Error:
 if( DAQmxFailed(error) )
  DAQmxGetExtendedErrorInfo(errBuff,2048);
  // DAQmx Stop Code
  DAQmxStopTask(taskHandle);
  MessagePopup("DAQmx Error",errBuff);
 return 0;
i dont know what tio write in the  DAQmx Write Code section i looked for some examples but didnt find any.....
Kobi Kalif
Software Engineer
Message 1 of 8
(5,299 Views)
Accepted by topic author Kobi_K
Hi Kobi Kalif,
The DAQmxCreateAOFuncGenChan is only supported with our NI ELVIS products. To create a sine wave using your PCI/PXI-6733 please look at this example:
Start»All Programs»National Instruments»NI-DAQ»Text-Based Code Support»ANSI C Examples»Analog Out»Genereate Voltage»Cont Gen Volt Wfm-Int Clk
This example creates a lookup table of values using the math.h library. Then this lookup table is read at the speed of the sample clock. By default it creates a lookup table of 1000 points and the sample clock is set at 1000 Hz. This will genereate a 1 Hz signal. The ratio between the sample clock and the number of points determines the frequency of the output. If you had a lookup table of 1000 points and a sample clock of 10000 Hz, the frequency of the output would be 10 Hz. You can change the amplitude of the output by changing the default gain of 9.95 to anything between 0 and 10.
Steven K.
Software Engineer
Message 2 of 8
(5,275 Views)
Thanks but one last thing ,
can you explaine the other values in
 data[i] = 9.95*sin((double)i*2.0*PI/1000.0);
9.95 is amp .
what are the others ?
Kobi Kalif
Software Engineer
Message 3 of 8
(5,253 Views)
Sorry plz ignore the last question 🙂 thanks for the help !!!
Kobi Kalif
Software Engineer
Message 4 of 8
(5,249 Views)
Dear Steven:
        Could you tell us , if wan to Generating 0.1~0.001HZ Sin Wave, Then how to change the Sin Generate func.
9.95*sin((double)i*2.0*PI/1000.0); --->the example Generate 1HZ Sin Wave.
9.95 is Amp
And If want to Generate other wave(ex: Triangle wave,Sawtooth wave,Square wave) the  Generate function
Thanks your kindly support!
Message 5 of 8
(5,126 Views)
Can you provide me with the example that you are using so I can see what the options are?
Thank you,
Justin
Justin
Product Support Engineer - Conditioned Measurements
Message 6 of 8
(5,100 Views)
Hello Justin
        attach my example code, then it generate 1Hz Sin wave sample,(How to generate 0.1Hz base Sin Wave function?)
then if want to generate continuous 2.7Hz Sin wave the rule
float data[1000] = {0.0};
float fFreq = 1.0;
 for(int i=0; i<nDataSample; i++)
   data[i] = 1*sin((double) i*2.0*PI*fFreq/1000);
// fFreq the generate 1Hz continuous Sin wave,
// But if change to 2.7,then it couldn't generate continuous 2.7Hz Sin wave
 DAQmxErrChk (DAQmxCreateAOVoltageChan(g_taskHandle,"Dev1/ao0:1","",-10.0,10.0,DAQmx_Val_Volts,NULL));
 DAQmxErrChk (DAQmxCfgSampClkTiming(g_taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
 DAQmxErrChk (DAQmxRegisterDoneEvent(g_taskHandle,0,DoneCallback,NULL));
 // DAQmx Write Code
 DAQmxErrChk (DAQmxWriteAnalogF64(g_taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
 // DAQmx Start Code
 DAQmxErrChk (DAQmxStartTask(g_taskHandle));
Message 7 of 8
(5,089 Views)
here is some information about sine waves,
hth, Wolfgang
Message 8 of 8
(5,079 Views)
