LabWindows/CVI
Get rid of Windows-style title bar on Image (NIvision)?
Can you get rid of the window-style title bar on an image (*Image)?  I am using CVI and NIVision library and don't want a big blue title bar that allows the user to close the image.
I also wonder how to keep the image on top instead of disappearing to background.  I searched and found answer for labview, but none for CVI.  should I make the child panel as suggested in the Labview responses to the same question?  Will that work in CVI?
Thanks in advance,
Blue
(3,200 Views)
Blue,
I have NIVision installed but rarely use it, I am however quite fluent in CVI. Can you post some example code that shows exactly what you're talking? Unfortunately there are alot of users that use CVI and alot that use NIVision, but not so many using both. Did you also post this question in the Vision forum? If anyone has run into this before, feel free to answer Blue's question, if not i'll still take a look at an example if you would be so kind as to zip one up and post it to this forum.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,181 Views)
