LabWindows/CVI
GetCtrlVal & CommandButton
Hy,
I'm trying to get a 'mouseDown'  or ButtonDown function by simple using the  function 'GetCtrlAttribute (panel, control, ATTR_CTRL_VAL, &btVal)'
But the value, as I presse down this button (or don't press) is in both case zero.
Any ideas?
thanks
franky
(3,601 Views)
try using this.
Obtains information about the state of the mouse cursor.  The X and Y coordinates are set to the position of the mouse relative to the top, left corner of the screen.
Any of the parameters may be NULL.
/*-------------------- Prototype ---------------------*/
int GetGlobalMouseState (int *Panel_Handle, int *X-Coordinate,
                         int *Y-Coordinate,
                         int *Left_Button_Down,
                         int *Right_Button_Down,
                         int *Key_Modifiers);
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(3,595 Views)
The reason why you cannot get the "button down" event is that on normal buttons the commit event is fired when you release the button: in fact you can press a button, maintain the mouse pressed and move the pointer outside the control and then release the mouse: no commit event is fired in this case (as is in almost all windows applications).
Sheetal suggestion seems the most reasonable way to handle your case, apart that it's a functon, not a callback, This means that you will need to call it in a loop or in a callback fired by another event.
Nevertheless, before the commit event is generated EVENT_LEFT_CLICK and EVENT_RIGHT_CLICK events are fired, so you could use them to trigger your function.
Another way to mimic a mouse pressed event is to change your button to a toggle button: in this case the commit event is generated when you press it..
(3,591 Views)
