LabWindows/CVI
GetFileAttrs Crashes CVI 2010 SP1 for 64-bit compile if Windows Volume does not exist
When I compile an application as 64-bit running on Win7 64-bit OS,  and use the GetFileAttrs function where the Windows Volume (say Z:\) does not exist,  the application crashes.  In Debug mode,  the application simple goes away,  whereas in run-time mode,  a fatal run-time error occurs.
This behavior is not observed if when application is compiled as 32-bit.
Message 1 of 11
(4,225 Views)
Hm,
I was wondering if I could reproduce this behavior. What I found out using Win7 64 bit, CVI 2010 is that even in 32 bit debug mode this function causes the program to stop without notice (I don't know if I should call it a crash, but status is not populated):
    ... something: executed properly
    status = GetFileAttrs ( "z:\test.txt", &a, &b, &c, &d );
    ... something: never executed
Also in my case the volume z does not exist
If I replace z:\test.txt with c:\test.txt I do get a return value of status = -1 (as expected, because I don't have a file test.txt)
Message 2 of 11
(4,223 Views)
You are correct, Wolfgang.  It does not work for either build.
Message 3 of 11
(4,216 Views)
It should be "z:\\test.txt". You are putting a tab in the string by not escaping the backslash.
Message 4 of 11
(4,202 Views)
Mohan,
You are right - partially Smiley Wink
  • However, the same tab is present in "c:\test.txt" - and in this case the function behaves properly, i.e. returns an error
  • Even a wrong argument of a function should not crash CVI but result in a meaningful error message
Message 5 of 11
(4,199 Views)
Yes, the "crash" is not acceptable and is a bug and will be fixed in the next release. I just wanted to point out the tab typo.
Message 6 of 11
(4,197 Views)
Thanks Smiley Happy
Message 7 of 11
(4,192 Views)
This issue has been reported internally with ID 343157. Just in case you want to track this. It should be fixed soon.
Message 8 of 11
(4,190 Views)
Hi Mohan,
I couldn't find 343157, neither in the current list of known issue here nor in the list of fixed bugs here
Message 9 of 11
(4,156 Views)
You are correct, it is in neither of those reports. It looks like the bug was accidentally mismarked to not be included in the list. It will update the list again.
The bug is fixed in CVI 2012. You should no longer see a crash with this function. Thank you for the feedback.
Message 10 of 11
(4,147 Views)
