LabWindows/CVI
GetFirstFi​le
GetFirstFi​le not workong properly.
Hello, after many working days and hours i can describe the problem in GetFirstFile function.
For explain this bug i create directory c:\try and another directory c:\try\Folder1.
#include <ansi_c.h>
#include <utility.h>
static char fileName[260];
memset(fileName,0,sizeof(fileName));
       GetFirstFile ("C:\\try\\*", 1, 1, 1, 1, 1, 1, fileName);
       printf("%s\n",fileName);
       //Here i change searching  criteria
       GetFirstFile ("C:\\try\\*", 1, 1, 1, 1, 1, 0, fileName);
       printf("---------------------------------------\n");
The output is
Folder1
Folder1
When i trying use  GetFirstFile ("C:\\try\\*", 1, 1, 1, 1, 1, 0, fileName); at start, i do not recieve anything (fileName parameter is empty). It's OK.
How can i solve this problem.
Best Regards
Boris
Best Regards
Boris
Message 1 of 10
(4,915 Views)
one possibility to solve the problem could be to use the return parameter of GetFirstFile. In case of success, it is 0, and only then you may assume the file name to be valid. If the return value is, e.g., -1, meaning that no file was found matching your search criteria, then probably the filename is not set by the function, reflecting its old value.
So you may try
if ( GetFirstFile ("C:\\try\\*", 1, 1, 1, 1, 1, 0, fileName)==0)
Message 2 of 10
(4,909 Views)
Sorry, It doesn't work!!!
For example: Put the code in Interactive execution in CVI and run the Code.
#include <ansi_c.h>
static int res;
       res = GetFirstFile ("C:\\try\\*", 1, 1, 1, 1, 1, 1, fileName);
       printf("Res = %d  FileName='%s'\n",res,fileName);
The output is:
Res = 0  FileName='Folder1'
Does anybody have a solution to this bug?
Best Regards
Boris
Message 3 of 10
(4,899 Views)
That's what I actually did Smiley Wink  and indeed I obtained an output similar to yours. However, my understanding is that this is more a bug of your code because of your neglect of the return value. Parameters of a function returned to the user are valid only if the function executed properly, i.e. without error. Obviously, according to the return value of this function, not finding a file is treated as an error and hence in such cases you must not trust any result obtained from the function, i.e. the name of the first file.
-> Did you try and check the return value of your second function call, too?
Message 4 of 10
(4,896 Views)
Ok. I understand, But res parameter mus be -1 in second calling function (when i cange a criteria to files only)?
Best Regards
Boris
Message 5 of 10
(4,892 Views)
Yes, for the second of your calls of GetFirstFile I would expect a return value of -1 if no file with the specified criteria can be found.
Message 6 of 10
(4,890 Views)
Yes, I would expect this to, but, it is not.
Maybe u have any solution......
Best Regards
Boris
Message 7 of 10
(4,887 Views)
It is working as expected in my case. I adapted your code as follows:
#include <ansi_c.h>
static int res1, res2;
       res1 = GetFirstFile ("C:\\Inetpub\\*", 1, 1, 1, 1, 1, 1, fileName);
       printf("Res = %d  FileName='%s'\n",res1,fileName);
       res2 = GetFirstFile ("C:\\Inetpub\\*", 1, 1, 1, 1, 1, 0, fileName);
       printf("Res = %d  FileName='%s'\n",res2,fileName);
In the given folder I have two folders, no files, the Standard I/O windows shows accordingly (and correctly, I would say):
Message 8 of 10
(4,885 Views)
It will be even more obvious if you reset your file name in between the function calls:
Message 9 of 10
(4,884 Views)
Oh Sorry. You Right.
My mistake.
Thank you very much.
Best Regards
Boris
Message 10 of 10
(4,881 Views)
