LabWindows/CVI
GetFirstFile GetNextFile
Hellow there
Does GetFirsFile / GetNextfile return the file names in sorted order(alfabeticly) or i must sort the incomming
file names manualy
Thanks for advance
Gabel Daniel
(4,253 Views)
Hello Gabel,
Using GetFirstFile and GetNextFile will return files in alphabetical order.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(4,218 Views)
Hello again,
I'm not sure what your application is, but I came across this interesting example using GetFirstFile and GetNextFile. It may be helpful in your development.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=BB1050C9963626C5E034080020E74861&p_node=DZ52146&p_source=External
Thanks.
Wendy L
(4,215 Views)
Hi Wendy
Thanks for your answer.
In All CVI doc's and help files your answer is not documented,i think it is an iportand fact to add to cvi help files.
as for my application: it reads files of data that was stored erlier by a2d system and 'playback' it
by a similar d2a system in the correct chronology.One of the tasks of my application is to retrive the data files
in the correct order as they was stored.The a2d application stores the file in the order thet the date/time is
embeded in the file name.
Gabel Daniel
(4,197 Views)
I think the GetFirstFile/GetNextFile functions return files in the 'natural' order of the filing system. For NTFS partitions, this happens to be alphabetical order (because the directories are properly indexed); but there is no guarantee that this will be true for FAT partitions (and probably won't be).
Martin.
Martin
Certified CVI Developer
(4,181 Views)
